Discuss Help with bathroom extractor fan in the UK Electrical Forum area at ElectriciansForums.net
I rarely do any electrical work anymore and seem to have forgotten most of what I've learned.
Must be my age.
Anyway, I've been asked to add an extractor fan to a bathroom (with timer) I've done this and added a triple-pole isolator.
What I'm asking is; how are the connections made at the switch?
The existing switch has two neutrals in connector block with a common and L1 making the light work.
How do I introduce the new 3 core and Earth at the switch and into what terminals do they go?
I know it's poor or just a brain freeze but either way, an idiots guide to this would be much appreciated.
Many thanks.
Must be my age.
I know it's poor or just a brain freeze but either way, an idiots guide to this would be much appreciated. And as the bathroom is a "special location" LABC will need to be notifiedMany thanks.
Also you need to make sure the Bathroom wiring and any wiring running through the bathroom is RCD protected.
Thanks Pete.
I probably didn't make myself clear.
There is no 3-core running from the ceiling rose.
The switch has a common and L1 connections with the neutrals in block. Can I introduce a 3 core at the switch (and with what connections) run that 3 core to the triple pole and out of the triple pole into the fan?
Sorry to be thick.
Many thanks.
There will be a permanent live, switched live and neutral and Earth at the switch in the situation you describe, although the switch may be a bit busy it's possible to do the connections in there.
Reply to Help with bathroom extractor fan in the UK Electrical Forum area at ElectriciansForums.net
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Hi all, wonder if someone can help me. I've bought a bathroom extractor and I do have the wiring there already (previous extractor was there) but...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
My extractor fan has given up the ghost this week and I was hoping to replace it myself, however I cannot do a like for like swap as the current...
