Search the forum,
Discuss home automation alexa or app controlled light switches in the UK Electrical Forum area at ElectriciansForums.net
I am trying to automate my home as much as possible having installed hive for heating and some light bulbs - however there are some rooms where the lightbulb option is not possible and I need to have automated light switches.
The problem is that all the ones that I have seen (which connect to Alexa) seem to require live and neutral wires but my bungalow was built more than 25 years ago and whilst i have a new consumer unit most of the wiring is the old UK live feed/return. All the switches I have seen so far require at least live and neutral to work. Are there some which will work with the older uk system.
Re-wiring is far too expensive as there are no conduits to enable easy feeding of cable.
Am I stuck with manual light switches?
there are a few auto remote systems where the receiver fits in or above the light fitting. compatibility with alexa and/or other systems is outside my scope of knowledge.
Reply to home automation alexa or app controlled light switches in the UK Electrical Forum area at ElectriciansForums.net
