Discuss Honeywell security alarm problem in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
G
gas tech
Hello, I have an issue with my house alarm system. It is all Honeywell and its a couple of years old. My bell box is making no sound/noise when activated.the warning light is flashing underneath.
It's a reson 8 bell box, on inspection in the bell box the timer is set to Test. There is a little link on the test pins, when I remove the link and put it across either the 5,10 or 20 minutes the sounder alarm goes off and doesn't stop no matter what.
What is the problem here? Battery, break in one of the cables?
Thanks beforehand for any advice
Below is a picture of the timer set on test I'm on about
Can you supply a picture of the connections for the bell cable within the control panel?
I'd also take a look at that sticker on the chip... something expired in June 2016, it looks like WARRANTY.
Has it ever worked properly? If it was working, it could be it's simply failed and needs replacing. However, having just had a quick look at some instructions, the TEST link should be set to a time, which I believe is the time the unit will sound in the event of a loss of connection to the panel. You should be aware that with the cover off (tamper active), the unit will sound until the cover is replaced (and possibly the panel is reset).
I've not worked with Honeywell gear, so I'm guessing.
Thanks for the reply,
Yes Thats how I read it the link should be moved to one of the times. I have replaced the bell box for new, the picture is of the old one so I could swap it like for like.
I'm sure it was working before but how if it was set on the test link?
When I replace the panel on the bell box and reset the panel the sounder is still going full blast and non stop.
Reply to Honeywell security alarm problem in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Hi I am helping with some village lights and need some advice as to a route forward (our electrician is unavailable for an undefined period) We...
Hello I recently purchased a nest smart smoke alarm. I currently have 2 mains linked smoke alarms (one upstairs and one down). My plan was to...
Hello, I’m not an electrician and I have a question in relation to Dimplex Duo300n. Some background information: a couple of months ago I have...
7K
