Discuss horstmann electronic 7 not heating water when set up to do so in the Central Heating Systems area at ElectriciansForums.net
U
User7
Hi,
I got my boiler control changed last week as the old one stopped working. The current one doesn't seem to be heating the water when I set it a range of times. It does heat the water when the BOOST button is on, but that's not enough for me. I believe I have an immersion heater and I am not on Economy 7 so my electricity rates are the same all day.
My question is: Dose the control somehow know when it is using Economy 7 or it just trusts you that you will set it up to work at the correct time of day?
Hi,
Have you flicked the switch to timed?
Hi, I have flicked the switch to timed and no, I haven't asked my engineer as it's my lettings agency that arranged him and he takes ages to response and return calls. I think that either he hasn't connected the timer to the boiler or there is something wrong with the boiler itself.
Reply to horstmann electronic 7 not heating water when set up to do so in the Central Heating Systems area at ElectriciansForums.net
Hi I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
Yesterday moved my Mum into her new bungalow. The Hortsmann had been off for a few months I suspect. The boost worked, but nothing happened...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi all, I've come back from a 5 day holiday to no hot water, and the Horstman Electronic 7 controller on (LCD display working) but the neon...
