Anyone have a one line diagram of a typical UK or EU hospital?
How are the emergency branches divided per code? How many ATSs? What is typical?
I presume since you haven't put a location and are referring to code and flashlights you're in the US?
Seems an odd request for just inquest
Ok, I'm learning all ready. What is the difference? The building never looses power vs just enough for what code requires be backed up?
No Break, exactly what it says no break in the supply
Stand By, Loss of power, everything dead until Genny takes over.
Like an uninterruptible power supply with a battery? What loads get that or are required to?
Normal supply run through an on line UPS, power cut, UPS takes over until Genny is up and running and takes over from normal supply, load shedding is in operation to shut off all non essential loads.
What loads would the UPS supply?
Also are the receptacles serving patient care beds fed by a dedicated electrical branch or ATS?
Earth
Hospital Emergency Power System
Cookie,
Cookie,
