Discuss Interesting Observation... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Could it be because the one on the left started feed in.
More likely one house has better insulation than the other.
it's not to do with insulation or the temperature in the house as the amount of snow on each roof is about the same. The most likely explanation is that good quality panels come with a hydrophobic coating on. this gives the panels a degree of self cleaning ability which will also reduce the adhesive force between the snow and the panel. Cheap panels either have no coating or an inferior coating. After several years in the optical industry I have seen good quality coatings and bad ones (from the opticians you shouldn't have gone to mostly!) and there is a considerable difference between the two. A good quality coating requires a high level of technical expertise and expensive equipment.
This is one of the things you pay for on a better quality panel
of course I may have my humble pie with ice cream if they turn out to be the same make of panel but thats my view of it.
Also knowing exactly the setup next door would be so helpful, which and how many inverters used, how many strings, panel voltages, startup voltages of inverter(s) etc etc
It seems you could learn alot from this initial observation........ and for good reading here - LOL
Reply to Interesting Observation... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
