pirate
Supporter
I thought I would take a few minutes to give my recent experience in wiring a large garage for power and an alarm circuit. This relates to clipped direct for all cables, using Linian clips.
A laser round the garage, drilling the 6mm holes. clipping the 2.5mm to the brickwork all went very well, and was quick. I've used these Linian clips quite a lot and I am a convert.
Today my pal was installing his alarm circuits, comprising , from the control box, a 6 core and 2 x 4 cores to one side, a 6 core and a 4 core to the other side, and on each side a 4 core alone to the sensors at the roller doors. The 2.5mm clips (actually the same size as the 1.5mm clips) coped fine with a 6 and 2 4s. The 1mm clips took a 6 and a 4 core, and the relatively new nano clips happily took the single runs of a 4 core cable. The nano clips suggest a drill bit of 3mm, but in the very hard brick we found that a 4mm was perfect, the 3mm being just too tight, although it may be ok in softer materials.
Not the most exciting story ever, but maybe it might assist some who are keen to have a single solution to supporting cables against premature collapse in case of fire.
Used them for the first time recently on an external Hi-tuff as I didn't want cleats on display. Very impressed with them, although the coating could be better as hammer chipped it on a few.
Only gripe is price, but I'd still complain if they were the same price as cleats 😄
It's an odd thing, but when looking for a fire-proof solution I can't really see any point in using other clips types, even where fire isn't an issue. You just carry a selection and use them everywhere. The garage in question has 5 doors, so protecting each escape route is important, so it doesn't make sense to mix types when one type does it all. I'd probably use p-clips for coax in an attic, but then I have a million of them to use up!
I saw them recently at the CEF 18th event in Dundee. I hardly need to fix stuff to bricks, etc, so not been looking but agree they look really neat and tick the boxes for cable-collapse regs nicely. Somewhere I have a Thor copper/hide mallet which would do to avoid chipping paint I guess.
Also remember to have some pincers if you need to get them out, the traditional carpentry style. This sort of thing:
I just had to Google what everyone was talking about. They look like really nice clips.
pirate
Supporter
Glasgow
United Kingdom
Electrical Enthusiast (Unqualified Hobbyist etc)
Just a wee take on wiring power circuits and alarm circuits in a garage
pirate,
Dartlec,
