Hello all
I am currently re wiring a flat which has a damp problem in the kitchen at the rear. I will be installing a 6" extractor fan with a pull cord on it to help reduce the damp. The fan will be supplied from the lighting circuit. I am aware that you need a 3 pole isolator when it comes to bathroom fans (even though I've never read the reg myself). Will I need an isolator for the kitchen fan as well?
Can you not just use a double pole pull cord or does it have an over run needing line and switched line? In fact you could put a 3 pole pull switch in if that was the case but I think they are chunky square things
If there is no timer overrun then you would only need a DP isolator and even that could be single pole in a kitchen, just use a DPSFCU or DP switch.
would it be better to run the fan off a non switch /spur to the fan form the lighting circuit .
having a pull cord on the fan, has the fan got auto shut off on the fan.
When I say it will have a pull cord I mean it one which will be attached to the fan. This won't isolate the fan for maintenance/ if there's a fault. I think a Switched fused spur above the countertop would be the best option. That would also remove an ugly pull cord!
by having a non switched or switch f/spur next to the fan for maintenance their will be a fuse for that by taking it out, weather it is near the counter top or not .
Suggest read the manf. Instructions normally fans without timer are down rated to 1A or 3A and proper isolation is required. Refer to Guidance Notes and BS7671
Newcastle Upon Tyne
Kitchen Fan isolator?
alex kane,
buzzlightyear,
