Discuss LED GU10 bulbs still glowing when turned off in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys,
Just need a little advice if possible.
I have recently fitted 6 GU10 Downlights 230V on a customers landing with 5W Cool LED GU10's. When he turns off his light one light is still slightly on. I know this has something to do with the two way switching for the landing and a bit of leakage but I have no idea of how to overcome the issue.
Can anyone help?
Dan
Just connect it between switch line and neutral...could be at the switch if fed or at the JB etc. If your not sure where switch line and neutral are you might have to get an electrician in :)
Reply to LED GU10 bulbs still glowing when turned off in the UK Electrical Forum area at ElectriciansForums.net
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
The G4 110V 3W dimmable bulbs I purchased work with a dimmer. I can brighten them and dim them, but when I turn the dimmer off, the LED bulbs...
Hi All, thanks in advance for any guidance you can provide. I will of course turn off everyhing at the consumer unit before doing anything. I...
