Discuss Light always on since light change in the The Welcome Forum area at ElectriciansForums.net
delooney
Hi all,
Another newbie to the site here, I'm hoping to look for some answers to some questions, and in the future looking for a local sparky for quotes on a new extension.
One question to start:
I have recently taken a Dunelm rose light fitting down and replaced with a bog-standard one from B&Q, however, the light stays on no matter the wall switch status. I'm sure I kept the wires/colours to the junction box the same.
I didn't keep the Dunelm light, so couldn't go back to check. I have checked the switch by replacing with another in the house, but get the same results.
Pic attached shows the wiring.
Thanks,
You've got the switched lives mixed with the permanent lives.
Without test gear you're not going to be able to tell. A 5min job for a local electrician. Wont cost the earth.
Why aren't you using the terminals on the light fitting
Does it go bang when you switch on the light?
He has the brown in the permanent live. Blue to the two blacks and brown to the single black. As Rob says get an electrician in to fit it correctly as I am assuming my method is correct.
as westy said.should work if you move the brown to the single black and shove the blue in the block with 2 blacks. better though his next post for losing the blocks. if that's beyond your capabilities, then a spark's call-out would be around £35- £45 to make sure it;s right and safe.
But the existing is wrong and non-compliant with the regulations, why would you choose to keep this with its increased fire risk?
Agreed! But I was not aware until this thread :)
Strange as all the lights in the house have blocks in and all the others I've replaced when we moved a few weeks ago, with no issues except this. They'd [the previous owners] even spent 1000's on the electrics too!! I will get someone out.It does seem there's not much cable 'up there' to make it easy (but I doubt that's a legit excuse!).
Thanks all.
Thanks all.
it's just that those terminal blocks pushed up into the ceiling are potentially dangerous. they have "live" terminals not enclosed.
There would also be non-sheathed cables not contained or within any enclosure in addition to the exposed live parts. It's wrong on a number of levels.
Reply to Light always on since light change in the The Welcome Forum area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
