Discuss main fuse in the Canada area at ElectriciansForums.net
O
ONIT
Hi Everyone
We All Know You Should Not Pull The Main Fuse, Its Down To The Big Boys From The Board.(in A Perfect World)
But If You Didnt Have A Double Pole Switch Fitted, And You You Needed To Pull The Main Fuse To Disconnect Main Tails In Front Of The Inspector From Niceic, Do You Think This Mite Go Against You.
So The Question Is-- Niceic Inseptor Checking Do You Pull Main Fuse Y/n
As Anyone Come Across This
All Replyes Wecome
in case he wants me to do IR TEST method 2 through tails (phase/neutral together) to earth hes checking board change on one job
in the extremely unlikely event that he'd ask you to do method 2 on the whole board i doubt he'd ask you to effectively break the law by cutting the seal (if it's there anyway) to get at the fuse. :)
All They Tend To Check Is Earthing And Cert Filled In Ok, Oh And Dont Forget A Sticker,they Love Earthing And Stickers.lol
You could say to him, I can't test it that way unless we wait for the electricity board to come out and remove the main fuse. Anyway, tails from the meter are the elec boards responsibility, so why should you test them?
Reply to main fuse in the Canada area at ElectriciansForums.net
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi Everyone, I have a faulty smart meter, its broken since I moved in and I am putting all my effort to fix this, I am a tenant though. A...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hi there, I run a recording studio out of an early 50's built warehouse. I've been having electrical noise and ground loops in my audio equipment...
