Search the forum,
Discuss Main Fuse in the Australia area at ElectriciansForums.net
What I do is cut the seal as near the back of the seal as possible , then once finished put a tiny dab of superglue on the cut bit to rejoin it, and rotate this join so is hidden behind the main fuse.
Dealing with EDF is like pulling teeth, so screw 'em. That's what I say :)
I’ve always been concerned over cutting seals just in case Me Meter Reader showed up just at the point the main fuse is being pulled! But after a recent visit by EDF to move a meter on a job I’ve changed my tune. Guys turned up to dig out the supply cable (As they have to dig out over a live cable) and was asked if I’d pulled the main fuse. To which I replied NO….lie,lie,lie! I was then asked to go do it….While they stood and watched! I will never not consider cutting a main fuse seal again but do draw the line to the meter one. I did read this week in Switched on magazine that it has been denied to train sparks for pulling fuses as there was insufficient response form the industry! Would be nice to be asked may be!
Just nip them up with your side cutters.
I worked for a contractor for EDF installing new connections (LV jointer) and they wouldnt give us the proper crimps - we just used side cutters/pliers.
i got some from ebay i had some which were crap most of the seals up here are plastic and code numbered so i seal using the metal seals now and use my crimpers on red that seams to work
Reply to Main Fuse in the Australia area at ElectriciansForums.net
I'm after advice on how best and safely to do a friends Fuseboard upgrade. Current setup is a Wylex 6 Way board with MCBs of 2x 6A, 2x 32A and 30A...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
This is an issue that is starting to get more of a ball ache for me, when theres a smart meter installed without an isolator and I really need to...
19K
Yes that old chestnut... It seems to invoke rage in some people but thats not what this is about... My question is has anyone tried to be sneaky...
Hi I don't know if I should ask it here or the main electricians forum. It's about CU change and the work around it and the CU change will be done...
11K
