Discuss Martindale Voltage Indicator VI13700G in the Electrical Tools and Products area at ElectriciansForums.net
I always thought that you have to calibrate only those instruments you use to certify
or am I wrong? A voltage indicator just either works or doesn't work, it doesn't give a value.
Hmm, I see what you mean; I wonder how much they charge to calibrate one of these.
Not sure I'd bother myself. Provided you check it at the time of use, I think I'd risk it!
[FONT=&quot]Approved voltage testers that indicate voltage in broad bands do not require calibrating. However, if the tester incorporates a meter it should be subject to annual calibration to maintain accuracy of the meter.
[/FONT]
so the martindale wouldnt but a Fluke T5-1000 would as it has seperate functions for continuity , current and voltage is that correcxt if so looks as if i will be buying a martindale and proving unit and hiding the T5 on assessment day lol
Hypothetical question here since I have no intention of joining any of the scams. If my Martindale was nicked could I use the voltage logging function of my Metrel MFT as a voltage indicator? Obviously it's calbrated regularly and the leads and probes are compliant and it's able to be checked on a known live supply ie the incoming tails
Hi mate they reckon you shouldnt use the voltage setting of the megger as it has a dial and when carrying out a voltage test could inadvertently knock the dial to a DIFFERENT SETTING
But my assessor didnt see any prob with me using a fluke t5- 1000 and proving it on a known supply?
I was told not to use and think it mentions this in GS38
I bought a fluke last year but will possibly invest in a martindale and proving unit so far jsut been using known supply like supply terminals or a socket outlet using the socket and see adapter
makes you wonder why they sell them with a voltage function if you cant use it
as my probes have 4mm tips or less on the megger so whats difference and even if you do knock the dial or set it to wrong setting the megger gives you a warning notice like when doing continuity if there was a voltage present the megger starts beeping with a warning notice on the dial
this is what i was worried about buying the fluke for me assessment last year thought he would pull me
but he jsut wanted to see me isolating locking off proving , testing for dead proving and posting warning notice he didnt even look at the fluke
I was worried for nothing as he put me at ease from the start
I was chuffed when i got a A no non conformancies so must have done somehting right
its coming around again in october seems a lot for the 2 jobs i will have notified maybe 3 by then lol
Reply to Martindale Voltage Indicator VI13700G in the Electrical Tools and Products area at ElectriciansForums.net
i need to purchase a voltage proving unit - i have seen Megger MPU690, Martindale PD690, and Socket and See SP400, and Fluke but difficult to...
Today I went to fix a minor loose screw on something and after switching off, etc, got out my Martindale VT12 continuity & voltage tester and...
Martindale voltage tester and proving unit, plus lock off kit for sale. All brand new and never used. I've come off the tools, hence the sale...
At the work place. When proving an 11KV Transformer is Dead. We have HV test sticks. With a function test. Part of the procedure is to function...
So earlier this year I obtained a large machine with a couple of 3 phase motors in it, and the rest single phase. I bought a VFD, correctly wired...
