Discuss Melted 13amp Spur switch in the Australia area at ElectriciansForums.net
Hi Luke teague,
I have come across a high resistance value in a new switch before and also in switch plates for lighting.
I guess its always worth a check of a switch before you install it.
I agree that a suspect would be lose connections and I have seen damage to the neutral terminals of showers and main switches.
Hope this helps,
Best wishes
Rex
But most storage heaters draw more than 13amps thats why a 20A DP switch is better. The SW/FS could of been getting hot for ages. Also the fuse could of been faulty
Reply to Melted 13amp Spur switch in the Australia area at ElectriciansForums.net
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
Hi all looking for a bit of advice. I've been asked to price a rewire for a early 70's build 2 bed apartment. The apartment block was built in the...
