Discuss Metal electric wall heaters - no cpc present. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I all 4 bedrooms in a rented property, there are cheap metal electric wall heaters. By design their cables are made of two wires - no cpc.They are plugged into a socket circuit with 32 A MCB.How would you code that? AThe heaters are not part of the installation, do i need to put that in the report?
Are they class I or class II?
Edit: posted same time as DS
If they are plugged in, no code as they are not part of the fixed wiring.
you may want to put a note on the report if infact they are class 1 appliances
if they are class 2 then there is no issue.
Regardless of whether they're plugged in appliances or not, you've identified a potentially dangerous situation. I would not be happy to walk away from that without first confirming whether the heaters are Class I or Class II.
If they are Class I then I would feel obligated to point this out to the owner, perhaps by way of a comment on the EICR, or in an email.
Although I suspect they're actually Class II.
Reply to Metal electric wall heaters - no cpc present. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
Hi, I have a property that I was looking to rent out. Its 12 years old property so relatively new. I had a EICR done from a qualified electrican...
6K
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
