Discuss Minor works - Like for like in the UK Electrical Forum area at ElectriciansForums.net
If a like for like change is done but it's not in compliance with the new regs is a risk assessment always required?
Also where does the "like for like" terminology come from?
that is not like for like. a RCBO is not "like " a MCB., even though it might fit in the same hole. a full test of the circuit and a MWC should be carried out. but i can't see the need for a RA. unless you have H&S numpties aboard.
This is a hypothetical example.
A lighting circuit with no rcd protection. The mcb needs changing for the reason specified by telectrix. Now does it need either an rcd or a risk assessment or can that be skipped.
as i said. a MWC completed for the altered circuit. why a RA? is your company run by snowflakes?
threasd going round in circles. where's buzz when youneed him?
The company is ran by curious people.
18th edition ads is not met without rcd I think because of Reg 411.3.4.
Mwc says departures may have a risk assessment "where applicable".
I want to know if this is applicable
As far as I am aware, the requirement for a Risk Assessment when omitting RCD protection, is in relation to socket-outlets intended to be used for specific items of equipment.
The term ‘like for like’ is not used within BS7671.
S
Someone just informed me that "like for like" is a part p term.
The requirement for ra for socket not rcd protected is specified but I'm talking about MWC which requires one where "applicable"
Yes I did just inform you.
There is one instance of the term in Approved Document Part P.
Yes you need to attach a documented Risk Assessment to the MEIWC if you are installing a socket-outlet without RCD protection.
If you are not installing a socket-outlet, then it’s not applicable.
A risk assessment is for departures from BS7671, see Regulations 120.3, 133.1.3 and 133.5 for such instances where this may be applicable. The risk assessment must prove that any departures do not affect the safety of the installation and persons using the installation and only apply to alterations and extensions to the circuit.
Regulation 411.3.3 is the only instance where there is a requirement for a documented Risk Assessment in BS7671.
There are other Regulations where a Risk Assessment is required, but there is no requirement for the Risk Assessment to be documented in those instances.
Reply to Minor works - Like for like in the UK Electrical Forum area at ElectriciansForums.net
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Thought it'd be interesting to see for those who are self employed. Work for themselves. As I'm doing level 2 . Nice to see how others already in...
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
