S
spike47
I have a Split consumer unit , containing a 80 amp MCB Main Switch with 6 MCB's and a 60amp RCB with 6 MCB's . Question what do I put on each side . I have the following circuets :
1- upper ring main .
2- lower ring main .
3- upper lights .
4- lower lights .
5- cooker .
6- centra heating .
7- garage .
8- immersion heater .
spike
buy some RCBOs for the non-RCD side.
Hi
Thanks guy's for all your input , I have just purchased anther 60 amp RCB main switch to have both sides of the split , RCB protected .
should of done that at the begining .
thanks again
spike
Main switch?
You need a main switch and 2 rcds, is that what you mean?
If you fit an RCD main switch, all circuits are then on 1 60A RCD.
Kind of a moot point but if you end up with the right Consumer Unit and it has two RCDs I'd put immersion on one side and central heating on tuther.
But so far the signs are not good.
Where you based? It might be worth getting a look in from someone if only for a corrective tightening of your sphinacker to avoid tacking off course.
Sorry worded that incorrect , yes it is a 80amp main switch feeding 2x 60 amp RCB one for each split .
Main switch?
To be honEst Ive gone reet off dual rcd boards. Started just using Rcbos only, cheap now, and you get more circuits in a board.
MK Split Consumer Unit
Talk Electrician Forum
spike47,
cbw,
