This may be me just having a bad day but installed 12 MR16 24V downlights, customer requested led, ordered them from toolstation as it was literally two second walk. all connected and fitted etc, big switch on and all i got was a little flash from some and nothing from others! made a test set up and tried with and without transformer, contacted manf they reckon they should work and that they maybe dodgy batch... all 12? any ideas guys? probably such a simple answer but today brain doesnt want to function! thanks!!
surely they.re 12volt and LED lamps require the correct trannies/drivers. you will probably need to replace all the trannies
but they do need a tranny suitable for LED. not sure what they are called, constant current or constant voltage or someting. some trannies require a minimum load or they shut down. haqve you measured the volts at the lamps when switched on?
i'd take a tranny and a led fitting to the wholesaler . fit a 13A plug and get them to plug it in.
you get constant current and constant voltage, and I have fitted a current driver as specified to a firstlight fitting that just pulsed, ended up going back with a firstlight driver and it worked fine, even though the specs were the same for both drivers....
sounds to me like its a driver problem, is there a recommended driver for the fittings?
Did you wire it so there was a transformer per lamp or did you run multiple lamps of a single transformer? If it's the latter it generally won't work as the transformers don't like it. Quick fix is replace the transformer for a 12V LED driver. If it's the first scenario then the lamps and transformers may not be compatible. Again replace the transformers for drivers and all will be well.
Norwich
MR16 LED problem!
Australia
gazzamikes,
mogga,
