Hi
I'm a product design student working on a project and am looking to get some advice.
I would like to buy a cheap test instrument that can carry out the following earth continuity test.
Maximum resistance 0,50 ohms measured by passing a minimum current of 10 A at between 6 V and 12 V for at least 1 second.
Basically the component is two pieces of metal held together with machine screws. The metal has been powdercoated and I have removed some paint under the screwhead. I want to check enough paint has been removed so that it would pass the above test.
Would a cheap multimeter be able to do this?
I have looked at continuity multimeter videos on youtube but I can't see how you can set amps and voltage on the continuity setting.
Many thanks
Hi
Many thanks
I suspect a cheap multi-meter is going to require a jump-start pack:)
You won’t buy a cheap new tester that is capable of such a test current.
Multimeters will produce a tiny test current, and a continuity tester used for general electrical installation testing normally tests at 0.2A.
How specific do the test conditions need to be and how accurate the results?
If not too specific then a portable appliance tester would normally have a test function which passes up to 25A to take a resistance measurement.
Second hand portable appliance testers are often quite cheap on sites like eBay, but are unlikely to be calibrated.
Alternatively you could hire a high current ohmmeter, also known as a ductor, low reading ohmmeter or DLRO which will be capable of doing the test with good accuracy.
Many thanks for the replies. I'm sure the university will have the equipment I was just wondering if there was something I could use at home. Just a quick question - what difference would it have on the result passing 25A to take a resistance measurement (using a pat tester as in the previous post) compared to 10A (the requirements of the test I would like to carry out)
*Just to be clear please don't worry I'm not wiring anything or anything like that it is just for a design project.
passing a higher current would better highlight any poor continuity. PAT testers cand do this as they use a low (non-lethal) voltage.
in This application there is unlikely to be a difference in using either test current as long as the item under test can conduct 25A for the test duration without overheating.
Ok that makes sense. Many thanks for explaining.
I have borrowed a Seaward PrimeTest 100 which gave a reading of: Rpe 0.06Ω.
On the back of the primetest it states the following:
Range:
Rpe (+/-200mA) 0.05-20Ω
(Uq>4VDC/In>200mA)
Riso (500v) 0.5-20MΩ
(Un>500VDC/lk<2mA)
Leakage (RMS)
Class 1, 0.25 - 10mA
Class 2, 0.1 - 3.5mA
Cord, 0.1 - 3.5mA
I was wondering if someone could advise what current and voltage the PAT tester used to carry out the test.
Thanks again
looks like 4Volts and 0.2Amps, presumably that’s a battery powered tester?
I’d forgotten those things existed when I suggested a PA tester, I was thinking of the proper mains powered ones which use a decent test current.
London
Multimeter - basic continuity test
Electrical Tools and Products
Filby66,
Filby66,
