- Reaction score
- 17,090
It supports a top entry, and I should think the isolator would support a botom entry as well.True but the commando plug doesn't support side entry
Discuss Need Some Advice / Guidance in the Commercial Electrical Advice area at ElectriciansForums.net
Top of the plug to bottom of isolator!True but the commando plug doesn't support side entry
RightI see sorry for the wrong end of the stick
Reason why it needs to go to the left is there's a transformer (110) that sits on a bench below
That just clears the isolation was moved for the sparkys to run there wires
Right
Confusion Rules OKSorry for my confusion and added confusion
That SWA install looks a bit ropy no cleats!Bit of a conclusion
Sparkys finished up and final tests passed etc
Well yesFixing / clip just above trunking right side (doubt you missed it ) so your saying from there to the board needs another clip ?
Well yes
Reply to Need Some Advice / Guidance in the Commercial Electrical Advice area at ElectriciansForums.net
