Search the forum,
Discuss Neutrals at switches in the Australia area at ElectriciansForums.net
Well, ....seeing as your hiding all the other connections anyway, why not?? Neutrals at switch points when there not needed is a nonsence!!
i nearly always do it this way
better for most modern lights that only take tiny cables , looping at the light on a modern light fitting nearly always means a j/b which is poor practice
at the switch all connections are available and easy to work on.
the loop in system never came to prominence till the early eighties before that the neutrals were taken to the light switches or junction box's i.e. if a house was split level jou had a j.b in the upstairs landing servicing the downstairs lights and one in the attic for upstairs. Benefit is you only have one cable at each light fitting point.Another method is to use 10A D.P switches i.e. MK K4876WHI.
I have never seen double pole (2 plate ?) switching on a light circuit but I have seen a neutral passing through a lightswitch due to the way it was wired years ago ie fuseboard at low level conduit out to a 4x4 in the hall and a conduit to each light point via the switch and with single cables the neutral passed through but with T&E you tend to see a neutral joint but in this case someone has decided to double pole switch the lights.
On other thing to point out power sockets and fuse spurs are beginning to be double poled switching and when you think of it this is a good thing if you have a neutral to earth fault downstram of the switch/socket and theres a RCD involved as well
If there's no need for a neutral at the switch, then No i don't like it.
Strong views on this subject :)
Only picked out this quote just to emphasise the word like
Like it or dis like it ?
I have no issue with either method,they have advantages and dis advantages
Like is not in the Brb :cool:
If you approve of one over the other,what reason can you give that is backed up by the book ?
If you cant give a book reason there is no right or wrong way :)
Loop in system to ceiling rose everytime for me. New fittings can be connector blocked at rose which is essentially what a ceiling rose is. Cables are accessible then and a JB above ceiling is not needed.
Can't see a problem with it at all, and have wired 100's of new propertys this way! If Ikea and co start designing their fittings to be slightly more accomdating to receiving 3 cables then maybe i'd think twice!
Let me put it this way then, .... I wouldn't and haven't allowed it on any of my projects in the past, and wont allow it on my next project!!! If a neutral is needed for outside lights and the like, fine i have no-problem with that, but i do have a problem with using the switch points as junction boxes as a wiring system!!! No Way Ho Say!!!!!
Only ever seen this tried once on a project, and that was on a stand alone smallish building on a large shopping centre complex. In this case the building was very much like a normal house build, and using T&E wiring methods. Only caught it after a good 2/3rds of the first fix had been installed. Just the same, ...it all came out!!!
Reply to Neutrals at switches in the Australia area at ElectriciansForums.net
hello guys, hope you’re all well. We are looking at installing the Hager SFT240 changeover switch to three live aboard boats with an electric...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi folks, I’m new to the forum and it’s this issue that lead me here. So first things first. I was looking to wire in a Smart Relay at the rose...
