spud1
Hi,
Has anyone tried the newest version of the NICEIC Online certification?
I tried it after attending a local techtalk.
It was ok... but I found the first thing I did on it (an EICR) took me over 3 hours to process!
I cant decide whether this was because of user unfriendliness (form fill style format seems to slow circuit detail and test result entry right down! Not to mention observations entry !) or my inexperience with using the system.
Not to mention the £1.00 per cert it costs! (Bit pricey in the grand scheme of things)
In real turmoil with this, please help!
Better to buy a package that you can run locally on your PC if you ask me.
The scams don't deserve andy more of our money!
I have been mostly trying it this week too. :49:
I have so far done 2 EIC and 2 EICRs on it.
Before this I have used the templates in excel. But now I am looking to get a more professional look and I can't be bothered with updating the templates to AMD3.
I have looked at the standalone software too
I found the first one is a bit of a bind but you can copy your certificates as template for new ones so hopefully that will cut down on entering all the usual LIMs and Ticks, plus there are some built in templates (I use the 10wayRCBO board one),starting from a template is much quicker.
Whether it's worth a pound a shot I don't know but I will stay with it for one year till my next assessment and then make a decision then.
The PC packages want about the same money for the year and I think I will get better support from NICEIC (i CAN HEAR YOU SOBBING AT MY NIEVITY YA KNOW)
Worth noting that lot of council/government work (this side of the pond anyway) require the NIC EIC AC cert numbers.
I'm not with any scheme as at present I have no need to be, but iirc those numbers have a little cost attached to them as well...and no standalone test software is cheap (EasyCert around £200 to buy + £70 a year to license iirc). So the NIC stuff seems quite reasonable, given what you are getting. If it can notify BC in England/Wales I'd say its a bargain (not sure if it can? again not had the need for that!)
I use the NICEIC online certification every day, at least one cert every day and an EICR every 10 days, Its very fast, quick and easy, excellent layout and navigation, I can knock s minor works very out in a couple of mins, a full very with 10 circuits in about 10 mins or so and an EICR in as long as it takes to input the problems found.
i like it and would highly recommend it, and at £1 per cert it's very cheap and think it's the best thing out there, significantly better than other software.
Yes it does the BC notifications too, very very quick and easy, it offers you the BC notification at the end when you complete the cert.
Out of interest which other software are you comparing it to that you've used?
I've seen three others and cannot think what it was called but icertify was one of them.
At at least the NICEIC online doesn't cost you other than per cert, no software to buy etc and can access it from anywhere.
its only opinion.
its only opinion.
when you have access to the internet!!
Yeah but you don't need to fill in a cert to hand to the client there and then on the job... I always go home and email it over. I just make notes then fill it in at home.
Lol. That's my problem. This year I was criticised at my annual 'assessment' for not using their software until I pointed out the lack of Internet access! They even tried to suggest I should have a card reader. I can't get 3 G, I can't get a phone signal much of the week!
i use easycert. Don't recall it costing hundreds of pounds. Works great on the iPad.
How can they justify charging you for a electronic cert? Do you alsompay for the software?
At your claimed rate of 1 cert every day and with there being 240 working days (assuming 5 days/week 48weeks/year worked) then you are paying £240 per year. Compared to something like pirform which is £70 per year for an unlimited number of certificates it doesn't look all that cheap does it?
spud1
Somerset
United Kingdom
NICEIC Online certification - Opinions please
NICEIC Certification Scheme
Certification NICEIC, NAPIT, Stroma, BECSA Forum
spud1,
andyb,
