Discuss No cpc on lighting and no neutral continuity on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
I’ll keep you posted on the outcome. I’ll speak to client and hopefully they agree and I’ll change the metal fittings for plastic pendants. Also rectify neutral fault.
I kind of expected to be torn a new one. The assessment is this Saturday. I’ll try and get it sorted this week. Thanks
Nobody has ripped into you Muzza, just explaining the error of your ways, we can't all be perfect, don't take it to heart. Learn by your mistakes, bet you won't do it that way again, so lesson learnt.
Agreed, I take on board all advice Pete. I meant the from the assessor Saturday.
I’ll read the guide shortly Murdoch.
Worth printing out and explaining to the Assessor what you have learnt, you never know, coming clean sometimes goes in your favour. worth a punt if you ask me.
Please let us know how you get on.
I understand that Andy but what I meant was would it be an out right fail or are you given the opportunity to rectify with a revisit? Or possibly just photographic proof that the remedials have been done without a revisit? Thanks
That would be down to the assessor. I would reckon you would be questioned about any serious non conformity related to your work. I also reckon you would have had to have demonstrated high levels of negligence and incompetence to actually fail though.
The way the NICEIC is run these days I would reckon it would be a chargeable re visit for non conformity, it certainly would be for a "fail"
Knowing the NICEIC if its them, then worse case scenario unless the install is really really bad is they will arrange another assessment visit in due course once any issues have been rectified - for another fee of course.
They do like to get you to do your RFC tests though and you could risk it but if they ask you to test that circuit you are up the creek without a paddle. dont try and blag it, you have time before Saturday to sort this but need to get working and to be able to explain to the assessor what you have done and the reasons why. let us all know the outcome.
Reply to No cpc on lighting and no neutral continuity on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hi all. Reasonably competant non electrical engineer homeowner here. I have a question for the experts: I recently replaced a horrible...
