Morning all
Bit of advice please. I have a dedicated distribution circuit that was set up for a garage, that was never built, to the outside of my house. Its 6mm twin and CPC fed from a 32amp MCB. It now terminates into an outdoor double socket.
I want to extend the circuit and put some sockets around the outside of the house and one at the other end of the drive.
Now I'm wondering wether it is best to use 4mm SWA to create an A2 radial circuit. I see this as the best option as it'll give the greatest range for products to use in terms of wattage capacity. Or to use 2.5mm from and FCU at the point it comes outside and create an A3 radial.
I know that 4mm can handle everything, and i'm pretty sure that 2.5 would as well. We don't have a hot tub or any other high wattage items, but I like to be safe for any future purposes. 4mm is obviously more expensive and 2.5mm is easier to work with.
Volt drop is not a problem with the distances required.
I'm new to the industry and learning all the time.
My thoughts are, do the lot in 4mm.
