I can not make up my mind what to do for the best.
I've now encountered this a few times so just want peoples thoughts on this situation
I have a customer who wants single socket fronts swapping for double conversion sockets they don't want the mess to the decoration.
I went out to quote for the work and check the wiring all PVC so good there but there is no RCD protection on any of the 3 socket circuits. The board is a GET 60898 MCB board confuses me why people installed boards with no rcd protection at least on the socket circuits.
So if i look at installing RCBOs in-place of the breakers its very expensive plus GET doesn't exist anymore as i believe schneider brought GET out so at best im hoping one of those RCBOs will fit.
But doing this means that the 3 RCBOS that are required cost more than the materials cost for the sockets and customers are not prepared to paythe extra cost.
So my question is as i'm just replacing the socket fronts and not actually altering the wiring do I need to install RCD protection to the circuit? If I was altering the circuit I would of course install it with RCD protection. I always carry out testing and provide a test certificate but I know from conversations on the forum before that some of you suggest that simply replacing an accessory front doesn't require testing and certification.
So just want to get peoples thoughts as its adding an extra 72ish quid to my quote. My thoughts are not to do the RCBO addition as i'm not altering the circuit just doing replacement. Then listing it as a note on the test certificate
Cheers for your thoughts/recommendations
I'm not sure I agree with that.
Profile information is personal data, of a sort, and as such users are perfectly entitled to share it with as many or as few people as they like.
Some folks are naturally wary of sharing everything and anything on line.
Given the current climate with Facetwitgoogamabobs I would say rightly so. :)
Except, of course, that the real problem is not the occasional internetter / "stalker" curiously peeking into profiles one at a time but the mass data loss experienced by web sites when they are hacked and the details of everybody stolen en masse.
In that scenario having a profile that is marked for limited access will be a completely useless form of defence as your data is going to get stolen regardless, along with everybody else's.
Glasgow
Business Name
Udell Electrical Services ltd
Peoples thoughts Rcd protection
Gazthesparky,
Spoon,
