davek
Hi all
Is it essential to have a proving unit at your part-p assessment, I know we should have one, in reality how many actually use one.
regards
Dave
what he said ^^^. prove on the incomer.
would that be acceptable, to the assessor my job is a consumer unit would he not possibly argue, I could not prove unit after confirming supply is dead.
Hi all
regards
Dave
Being a professional Electrician I use voltage indicators daily and so I own a proving unit. I would expect other tradesmen own them as well as they are an essential piece of equipment IMO. As for part p guys I have no idea if they even know how to use the voltage indicators let alone how to prove they operate correctly.
you would isolate by turning off the main switch in the CU. the top terminals will still be live to prove your tester. whatever you do, don't pull the DNO fuse to isolate.
yes its acceptable to prove on a known supply as Tel says i.e.the supply side of your main switch download document GS38 its all you need to know about test equipment and requirements
The trouble is though what if the voltage indicators show no voltage at the main switch terminals? without a proving unit it is just hard to know whether there is power there or not.
if you test when the system is energised and your voltage insicator shows nothing, it;s a pretty safe bet that it;s knackered.
Well I am not going to get into a major debate Tel. However my view is when you switch the board off you could actually remove the cover and test the supply and think it is obvious it is on. if the testers do not show a supply you could assume they are not working correctly. Now in this circumstance fair enough as it is a domestic premises as were talking part pee it isn't a problem. What if you were testing a dist board connected to a stop button via a contactor or a dist board controlling lighting via a timeclock? the only way to be a 100% sure a supply is isolated or live is with a tester which has been proven to be functioning via a proving unit, as far as I am concerned this just proves how carp the inspection system by these schemes are. They do not ensure the guys are adequatly trained or know how to test, I could go on all night regarding safe isolation ans testing with instruments but I have already bored the pants off myself :cool3:
think debate done I will just get one offset to tax lol
cheers guys not worth the fail as will end up buying one anyway. any recommendations
totally agree with you there, mike on being certain, but with domestic testing on a "known live source" is, IMO, acceptable. with industrial, where you have 3 phase and maybe more than 1 source of supply, then you are 100% right, but that is usually beyond the scope of a Electrical Trainee.
I have the ethos unit, cheap and reliable
- - - Updated - - -
Yeah fair enough tel.
here, under £50 for a dilog.
Proving Units - ISSWWW
careful - there seems to be confusion as to the type of proving unit being discussed:
Is it a voltage proving unit for your voltage tester
or is it
a calibration proving unit to ensure your tester is working as it was when calibrated last.
Early posts seemed to be discussing the former whilst the later ones are discussing the latter.
The Dilog unit you are referring to is the latter.
my mistake. looked at the spec on it and it's not a proving unit. it's a checkbox.
managed without one for 40 years. ain't going to waste good beer money on one now.
My thinking is that the proving unit is the known supply and therefore should be used prior to any testing, I understand the veiw that how do you know the proving unit is ok, but you could go round and round this till the coos come home
I believe we may have just discovered the basis of ...............
... PERPETUAL MOTION !!!!!!
Hi guys,met Dave this morning and sorted him with a proving unit,he,s a sound guy just a little bit uncertain on some things,we,he all been there so let's try and cut his him a bit of slack,after all we,be all been there haven,t we
Agreed Phil and it not road best travelled alone something I think some members forget, also the underlying object of a forum is a exchange of information and frank exchange of veiws
without prejudice
Pict
I've found I've never needed to use a proving unit as either I can meter the incoming tails (as mentioned above) or just do a 250v IR test on my voltage detector, don't see why I should spend £60+ when I don't need to...
you guys know my time is done on the tools now,but I remember how hard it was when I started,just glad I was able to help out a fellow sparky by letting him have a proving unit and lamp that I didn't need,at a fair price.It,s hard enough these days trying to find work these days and the cost of kit is ridiculous at times.
When I was an apprentice it was either a neon screwdriver or a lamp with two bits of wire,but mostly proved to be dead if the fuse was out,switched off or the lights went out.
Proving unit
Thread Tags
davek,
PEG,
