E
electricnova
Hi,
I have taken over a design engineering job for industry.
The design is using a 400V/110V transformer. Usually, the 110V is single phase. However, in this case it is giving 110V 3 phase 32A.
The 110v 3 phase is for use with 4P 110V socket to run a pump.
Being in the UK, I am used to seeing 110V single phase for this application.
Can someone explain why the 3phase option will have been chosen instead?
Any diagrams will be welcomed.
Thank you
Thank you
(this is the configuration in my original post)
