From a 100 ohm TT earth, to 2.5 ohms with bonding in place ...Now that's impressive!!
A good long run of metal water pipe will beat most rods any day (even long ones :wink:). My sister's place is currently earthed by the water and gas pipes, and the Zs at the sockets is around an ohm.
I'm still awaiting the call to regularize the situation, but I won't push it unless I hear that the services are being 'upgraded' to polyethylene.
Luxury. When I were t'lad down t'pit we 'ad to test by stickin' ower tongues onto t'terminals. Then go back t t'ole in road, get up an hour before going to bed, and father would slice us in two wi't'breadknife. If we were lucky!
Luxury!
I have been told by one of our trainers, that I cannot use my drummond/test lamps anymore, because if any micro generation installs present test lamps will not pick up below 50v, must use approved volt meter.
And if you ''DON'T'' work on any micro generation installs?? These cretin bloody college tutors these days, seem to like making up their own rules!!! Get in contact with the manufacturers of the ''Drummond Test Lamps'', and tell them that you cannot use their test equipment anymore, cause your tutor told you so and see what they have to say!! lol!!
Except for the fact that metal service pipes (Copper, Lead, Galv Steel) are generally not laid in the ground ''Bare''!! They will almost always be protected against corrosion!! The old provision, was something like a Denso tape product (a thick grease impregnated webbed tape) . So not exactly the best conductive medium to the soil!!
That was my thought IF YOU DON'T. not gonnar argue with SSE trainers no point!!!. They only had me in for the day to update my MOCOPA cert. lol
We did some work a few years back and because we were working alongside networks engineers they insisted we used martindale test lamps.
