E
Engineer54
Hi to all you solar chappies,
Need a little advice on a 11KW stand alone PV irrigation pump installation.
Not done much at all with PV installations and trying to get some of the information i need off the internet is proving difficult especially as it all takes loads of time going through the bamboo internet wall from over here...lol!!
The pump i'll be working with is a 3 phase 11kw Franklin Electric submersible, working from about 550 feet of a 600 foot well. The areas i'm trying to gain some information on, is suitable panels, PV string configuration and connection diagram(s) showing PV combiners and PV disconnects etc, a suitably rated 3 phase output PV controller and expected overall system loses to take into account.....
If anyone can give me some internet links relating to the above and/or any useful comments based on experience of such an installations i'd be very much obliged??
Yes, basically raising water from a deep well, using PV power for irrigation purposes...
Its not going to be cheap to do so, Need to look at the start currents of the pump and how frequent you would like to use it. SMA Sunny Island option might be a good one, fairly plug n play and easy to put into three phase.
are you absolutely certain that it needs a 3 phase pump, and can't be run from a direct DC pump?
as you're introducing all sorts of expensive and lossy components by using 3 phase, though for a 600 foot well, I suppose maybe you do need that.
anyway to the question, I'd think you'd need to be looking at something like a 1000AH 48V battery bank, and 3 x sunny island / sunny back up inverters to give you the 3 phase, but is it 11kW per phase or total? They only come in max 8kW units. Can PM you the tech support contact details for SMA's design team who specialise in this kit if you want.
ALternatively maybe victron do some bigger units, but I don't really know how their range works.
Once you've got that sussed out, then work out about the panel requirements IMO.
No batteries on this little project, this is a straight stand alone system that fills a large storage tank, irrigation is by gravity feed from the tank. The 11KV 3 phase submersible pump is a fairly new unit that was temporarily used at another deep well location, and is being put into use for this installation. Any links you may have to the information requested in OP will be much appreciated...
Without a battery backup in the system you're on a hiding to nothing as the pump will have all sorts of requirements with regard to start up currents and voltages as well as running voltages and currents in order to pump the water, you won't be able to just take that direct from the panels and inverters.
Remember (I'm guessing) this is a field in remote area of china.. Appropriate technology..
My area is very remote and most if not all the irrigation is done by diesel pumps
Not cost effective to use standalone renewables yet
as gordon indicates, if this is a 3 phase pump then you'll need batteries and inverters to overcome start up currents and actually generate what the pump expects to be given power and voltage wise.
so yes batteries will need to be involved, unless your description of the pumps isn't accurate - have you got a link to the datasheet?
I would think the pump would start by a variable speed drive.
This stops the pipes from blowing joints.
So start current would be low
Unless i'm missing something here, why would you need battery backup if the PV system is sized correctly to the pump and it's requirements??
At the moment i'm waiting for confirmation of the pumps rating (eg if its 11 KW or 11HP.)
there is a little confusion going on there.
PV field irrigation system using a 3 phase pump...
Engineer54,
Gavin A,
