N
nazoom
My test examination board is domestic (single phase) and has two Distributor boards (D/B), one the main one with the main switch feeding a sub D/B, and the other one is external (sub) distributor board with no main switch but they are RCD protected and is fed by the main D/B. My question is when recording and testing the main board for PFC and Ze do we use the same values (measured at Main) for the both main and sub main distributor board or do I have to test both distributors independently and then record the different results in a different Schedule of test results sheet?
Many Thanks
Many Thanks
