Discuss Radial Circuit Protective Device in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
daver
Just been asked to jump on a job which needs completing before end of Jan.
The guy I'm helping is 74 and very experienced.
We are doing 8 double bedded flats. 5 Complete and 3 to go.
17th Edition split boards with 5 Circuits
Kitchen Ring - 32A
Lights - 6A
Smoke - 6A
Then we have 2 radials in 2.5 - 1.5cpc. 1 to 2 bedrooms with 6 double sockets total. Then 1 to living room with 3 doubles.
Each is protected with 16A Type B.
I thought it should be 20A, but he gave no explanation as to the 16A.
The only factors I know about is that the cables pass through some insulation (2M) and then are clipped direct and quite short runs.
The question being. Is he correct with his choice????
It doesnt HAVE to be 20A however if you can up it from the 16 then it is fine on a 2.5 radial.
The cable is rated around 26A.
depends on length of run, installation method and volt drop.
You could put the circuit on a 10 amp breaker if you wanted, probably not practical though. Get the guy to explain why he does things, it is the only way you wil learn..
there is no problem running any circuit on any size breaker as long as all requirements are taken into account, its just usally a 20a radial in 2.5 or 32 in 4mm etc....
Reply to Radial Circuit Protective Device in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I'm doing a college design project and need to choose a suitable range of circuit protective devices for the whole contact. I've chosen and...
I'm following a spark who used an existing Panel Heater circuit, for new gas boiler circuit 6 months ago. The panel heaters were removed, so it's...
5K
Summary (TL;DR) Several lightbulbs in my home supplied by one circuit breaker dim over time and go out in about a year. Right now, the ceiling...
