Discuss RCD for outside protection in the UK Electrical Forum area at ElectriciansForums.net
G
Gixxerdan
I have just recently bought a house which i am currently doing up. the consumer unit is a split load type with 1 rcd feeding the upstairs and downstairs sockets. I noticed that they have used the old cooker 6mm cable to feed the shed outside (t+e!) which I know needs changing to armoured and I think there should be rcd protection for it too as it is outdoors but what size rcd do i need? All there is is 2/3 sockets and two fluro fittings. Do i need a 100A 30mA rcd or would something smaller like a 63A 30mA do the trick? There is currently a chest freezer and fridge in there and the sockets will probably only be used for a lawnmower and strimmer. Also is armoured cable required or is 3 core sy substantial enough?
We have done our best to sort out your previous thread but is this going to turn into a thread a day to help you wire your house? .... Additional works or alterations in Bathrooms, kitchens and outdoors is all notifyable and at minimum requires a qualified registered electrician if you dont notify, the questions you ask are all easily looked up in the 17th regs or OSG book, if you dont have these and a full set of test gear then you shouldn't be undertaking the work without either a qualified over-viewer or the notified inspection after.
I realise you may be trying to save a few pennies but what is the cost of peace of mind that your family or tenants wont be killed by incorrectly existing or installed wiring.
From your other thread where you freely state you have no proper test equipment I have to agree with the rest of the guys here get a properly qualified and equipped electrician in to do the job for you. I can pretty much guarantee that it will cost less than a funeral and be less traumatic
Ah FUNERAL that's the second F word
Reply to RCD for outside protection in the UK Electrical Forum area at ElectriciansForums.net
Can anyone tell me the latest regulation for RCD protection on socket outlets, I believe it's required for sockets up to 32A but I'm told it...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
