Discuss RCDs and the Importance of the Test Button. in the UK Electrical Forum area at ElectriciansForums.net
yes....
and how many customers take any notice of the test quarterly sticker....or are shown functional operation on handover...
Of course my own house gets plunged into 'reset all the clocks mode' every 12 weeks, Mrs Rock just lives for the moment.
:joker:
This is the trouble. The conscientous householder may do the test a few times, but then either soon forgets, or thinks fup that, I'm not going round resetting everything every time I do this, and doesn't bother.
but these same customers who can't be arsed to do this simple thing won't forget to have the BMW/Merc/4x4 serviced regularly, just in case the brakes fail and they get splattered across the M6. but they're quite happy to put their lives in the hands of a ÂŁ20 device that may or may not work to save said lives. crazy.
The mentality seems to be "if it works its got to be fine." Maybe all RCD's should have a 12 week timer and alarm fitted to them which is silenced with the test button.
Failing that , ask the client what appliance they use roughly every 3 months , and then put the neutral in the earth at the plug top .
its the `well its always worked fine` mentality here again Tel....
till it fires that is...
if the RCD fails to operate 1st time using the manual test button then i was always told it should be condemned...but as has been pointed out....thousands of RCDs would then have to be condemned....a few goes usually loosens em up....
another one as well is an RCD should be replaced everytime it clears a fault....
suppose that puts testing them out to grass then....
Trouble is that there is no fault or service indicators so how do you ever tell it's cleared a fault
Most cars these days have a built in reminder for servicing and major faults so it does make it difficult to forget or ignore. May be there is an opportunity for someone to develop a consumer unit that informs the householder that their installation needs an EICR or other work carrying out
should make them like intruded alarms with a service timer. time runs out - leccy cuts off, call sparks.
Reply to RCDs and the Importance of the Test Button. in the UK Electrical Forum area at ElectriciansForums.net
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
I will start with apologies, as I have not thought this through very much (at all) yet and have just sat down with a beer.... meaning I thought...
Hi all,looking for some pointers to an RCD problem, I work entirely on large poultry farms, I've only been in post a year, at some point before I...
just a heads up to any member who is thinking of upgrading a faithful 1553 due to the type A RCD testing. here is a response I just received from...
