Discuss RCDs and the Importance of the Test Button. in the UK Electrical Forum area at ElectriciansForums.net
yes....
and how many customers take any notice of the test quarterly sticker....or are shown functional operation on handover...
Of course my own house gets plunged into 'reset all the clocks mode' every 12 weeks, Mrs Rock just lives for the moment.
:joker:
This is the trouble. The conscientous householder may do the test a few times, but then either soon forgets, or thinks fup that, I'm not going round resetting everything every time I do this, and doesn't bother.
but these same customers who can't be arsed to do this simple thing won't forget to have the BMW/Merc/4x4 serviced regularly, just in case the brakes fail and they get splattered across the M6. but they're quite happy to put their lives in the hands of a ÂŁ20 device that may or may not work to save said lives. crazy.
The mentality seems to be "if it works its got to be fine." Maybe all RCD's should have a 12 week timer and alarm fitted to them which is silenced with the test button.
Failing that , ask the client what appliance they use roughly every 3 months , and then put the neutral in the earth at the plug top .
its the `well its always worked fine` mentality here again Tel....
till it fires that is...
if the RCD fails to operate 1st time using the manual test button then i was always told it should be condemned...but as has been pointed out....thousands of RCDs would then have to be condemned....a few goes usually loosens em up....
another one as well is an RCD should be replaced everytime it clears a fault....
suppose that puts testing them out to grass then....
Trouble is that there is no fault or service indicators so how do you ever tell it's cleared a fault
Most cars these days have a built in reminder for servicing and major faults so it does make it difficult to forget or ignore. May be there is an opportunity for someone to develop a consumer unit that informs the householder that their installation needs an EICR or other work carrying out
should make them like intruded alarms with a service timer. time runs out - leccy cuts off, call sparks.
Reply to RCDs and the Importance of the Test Button. in the UK Electrical Forum area at ElectriciansForums.net
Hi all,looking for some pointers to an RCD problem, I work entirely on large poultry farms, I've only been in post a year, at some point before I...
Hello everyone, I'm newly registered having read the boards from the shadows for a while. I have a question about neutral to earth faults and...
6K
I wired a new circuit in my garden last year. One thing I wasn't sure of but figured it can't be much of an issue was having two rcds on the same...
So to start off with i’ll tell you i’m a young electrician, 23, I am qualified but obviously will always be learning. Was carrying out an eicr...
I have just popped out to a frustrated customer who has had intermittent tripping of a 30mA RCD for years, on average 5 - 10 x p/month. It used to...
4K
