can anyone advise me on how you would wire up 8 downlights to be controlled by a remote control? also can the downlights be low voltage leds? any help would be appreciated
Just putting some in at the moment, low voltage LEds in standard fire rated GU10 housing wired as normal but to an RF sensor. Because they wanted them to be dimmable, in this case I'm using 2x "Taptile" controllers which are hidden behind the tiles. If it is a straight on/off then "lightwaverf" is also a reasonable option.
