Discuss Replacement access door on SECTOR consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Hi all, a couple of weeks ago I managed to smash to smithereens the transparent plastic access door/cover on my sector consumer unit, that's at the top of my stairs. I need to get a new door/cover to replace it.
I know all C/U's now are metal, but I was wondering if anyone has an old one, or knows of somewhere I could buy an obsolete SECTOR C/U just for the door? I guess it doesn't have to be SECTOR just as long as it fits...Obviously I'll be happy to buy the entire thing although I only need a part of it.
many thanks for reading...
I've been looking on Ebay. No good... Lots of Wylex.
the Plastic Equipment Enclosure as I believe it's called, measures -
325mm width
140 height
35mm thick at the top of the door
20 mm at the bottom.
the broken flap is not essential. without it the CU is still safe. bugger it. spend your pennies on beer.
Really? I bow to your superior knowledge but , my Sparky doesn't agree...
then he's an Arse. ask him if he can poke his finger into the enclosure. it's known as IP rating, if he knows what that is.
Have you thought of a part time job in the diplomatic corps?
Take the lid off first then tell him to stick his fingers into the enclosure....
I’ll get my coat
This unit was made by Electrium (parent company of Wylex, Crabtree etc). Give the technical/sales helpline a ring and explain the situation. They may have a front cover somehwere that you can order through your wholesaler. You won't be able to order direct. If there is a part number somewhere that will help them find the replacement part for you. From memory the comsumer units were sv something. Failing that give them the part number on the mcb and no. of ways of board and they should find it that
Reply to Replacement access door on SECTOR consumer unit in the UK Electrical Forum area at ElectriciansForums.net
I want to know if my consumer unit (together with the digital meter) which is in a special metal container let into an outside wall near the...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi, NAPIT report was carried out due to flood, all kitchen appliances, wall/light switches, fire/heaters etc need replacing. The electrician...
