I am not a electricion but are competetent in doing these jobs .if I change an ordinary wall mounted socket in my French house ,do I have to get it signed off
Who cares, it's France. They don't even earth half their sockets!
Speaking of which, make sure you swap it for a new socket of the correct type. You must have noticed but there are two standards of plug/socket over there.
France/Spain, it's entirely believable a competent UK Diy'er could do a better job than the native professionals :D
Just found this nugget...
"The wiring method applied depends upon the material being used and the person doing the wiring. The typical older French country properties employ a system whereby both power and lighting circuits are combined with a continuous pair of cables which run to every outlet, terminating into endless boxes hidden in obscure places with no earth conductor at all."
Sounds about right ;)
Full article here:French Electrical Systems - https://www.frenchentree.com/living-in-france/utilities/french-electrical-systems/, a read through might be useful ahead of doing any work. although it sounds like regulation over there pretty weak and not that well enforced (or even acknowledged perhaps). Imo, if you know how to isolate and dead test, no reason you shouldn't do the swap over. In the UK the problem is that most DIY work goes untested, but I think if you did get a local spark to do the work they might also not bother testing. There is a chance you will find other things to put right when you start looking though.. Have you opened up the old socket yet? You might get back there to discover there is no earth, even if it is an earthed socket type.
france
replacing a ordinery wall mounted electrical socket in france
roger gardner,
freddo,
