A
apefray
Hi,
Could you please offer a bit of advice regarding the following:
We currently have a ceiling rose which is connected to a wall switch and Pull switch i.e. 2 way switching in the old colours. I understand how everything is connected, but, we are replacing the ceiling rose with a remote controlled fan/light.
My question is, if I disconnect the feed from the fuse box lighting circuit to the rose and feed this to the fan/light (as it needs a permanent live connection), can I leave the wiring to the two switches as they are for the time being? I believe once the feed from the fuse box to the rose is removed and rerouted to the new fan/light, there will be no power present on the circuit to the rose and leaving the wiring as it is would be no problem.
Oh, and I should make it clear that the rose is still in the ceiling near the window and will be left as is for now, just removing the pendant and will not be used again. The fan/light is a new installation in the middle of the room and Im just looking for a feed for it.
