Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
If you use a ring,you will have 2 x 2.5mm at each socket which makes 5mm.If you use 4mm you will have to 2 x 4mm at each socket which amounts to 8mm apart from the last socket.IMO a better solution
what am I missing here. 2x4mm = 8mm only if the feed comes from both sides ie a ring. In the case of a radial the last socket and any intermediate socket has the same size feed cable. What did I miss?
