Hi guys new to the forum. I’ve landed on a job on a dental surgery. The plumbers have installed new heating and got water system and basically left me to wire it up. Struggling to get my head around it and could do with some help. They’ve installed two boilers that are going to work together, two pumps one for c/h one for h/w. There’s three zone valves two for downstairs and one for upstairs. There’s also a h/w cylinder with a cylinder stat. They then want three room stats for c/h two downstairs and one upstairs. Any would be appreciated cheers
It’s basicaly an S plan+
The only thing that has thrown me is the two pumps? what type boilers are they?
No valve for the H/W then?
Are you a qualified sparky?
Separate these zones and the hot water system and draw it out should be easier to get your head round
The pump on the boiler for the hot water circuit is unusual because it's usually inside the boiler but maybe a secondary return.
Cheers for the reply’s guys. Sorry I missed the valve for the h/w it does have one. The boilers are Worcester ones. I’m a qualified spark I work on mainly commercial buildings. Not done ant s plan since the am2.
Draw it out on paper for the heating separate from the hot water just to divide and conquer and you will see its rather simple as it's all in series pal.
You need to tell us.
so you have 3 heating zones (2 downstairs 1 upstairs) each one with a valve and controlled by a room stat
1 H/W zone valve controlled via tank stat.
two pumps one for the system? one for secondary return?
Is this correct?
Has any of this been wired or plumbed?
Hi Antony this is correct. They want each zone to have its own room stat if this is possible. Cheers
Yes one room stat to each valve one tip ask the plumber which valve does which area and mark up each stat. Look at Lee's wiring diagram. Ask the plumber what each component does and post some photo's if possible.
Warrington
Business Name
Rob electrical
S plan heating system
Rob brazendale,
Rob brazendale,
