- Reaction score
- 16,637
Ahhh your in Scotland explains a lot.
You're
Discuss Sealing a consumer unit entry points?? in the UK Electrical Forum area at ElectriciansForums.net
Awesome. Next time I'm south of the border we should hook up. We could call @Reevio and have a 3 someIf he won't date you I will..
Bring cheesecake..
Hi RichardAhhh your in Englandshire explains a lot.
Touche!
Can't answer some simple questions, has various videos showing non compliant work and doesn't like it when it's pointed out. Undertaking unnecessary work (and no doubt billing the customer). Childish comments vis vis 'bunch of old women' and now a dumb attempt at a veiled racist joke...
I think I have your measure
And to save you the bother - yes i wear a skirt, no I don't wear pants, yes I have a beard, yes I'm ginger (collar and cuffs), yes I eat intestines, yes I shag sheep (but not my own as that would be incest). Yes I like a pint of heavy and a dram of the uisge bertha. Yes I fancy the 'Sturge' (even if she looks like wee Jimmy Crankie) and yes I believe in independence.
Over to you now, lets hear your worst Chris...
Reading the last couple of posts it's starting to put the forum in a bad light.Okay Richy and Chris enough is enough this has totally side tracked the thread and turned into a baiting match. I have deleted one post so either reply with regard to the OPs question or don't post at all.
INTUMESCENT.I have taken a look at the video that was posted there was a big hole behind the existing consumer unit.
Now I have not fitted many Hager consumer units but it looks like there is knockouts on the back that knock out as a whole, not in parts so there is more aperture that is needed the only thing that can be done is make good the wall or seal the hole. How much is a tube of intermittent mastic?
INTUMESCENT.
No, Mate that would be intermittent.Is this something that only works some of the time ?
Nothing wrong with cheesecake.I have to apologise for that... Asking someone to bring cheesecake on a date is a bit OTT.... Soz...
Only if you get it all of the time, and not every so often. or intermittently. Soz Ant in one of those moods, forgive please.Nothing wrong with cheesecake.
Why is that spelt wrong on your post? glass houses Pete!!!No, Mate that would be intermittent.
Yes that's the word Pete can always rely on you I am surprised that you haven't found a bad spelling emoji yet.INTUMESCENT.
intermittent - Bing
Intelligent search from Bing makes it easier to quickly find what you’re looking for and rewards you.www.bing.comintumescent - Bing
Eh???Why is that spelt wrong on your post? glass houses Pete!!!
Reply to Sealing a consumer unit entry points?? in the UK Electrical Forum area at ElectriciansForums.net
