Discuss Sealing a consumer unit entry points?? in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Ahhh your in Englandshire explains a lot.
Touche!
Can't answer some simple questions, has various videos showing non compliant work and doesn't like it when it's pointed out. Undertaking unnecessary work (and no doubt billing the customer). Childish comments vis vis 'bunch of old women' and now a dumb attempt at a veiled racist joke...
I think I have your measure :p
And to save you the bother - yes i wear a skirt, no I don't wear pants, yes I have a beard, yes I'm ginger (collar and cuffs), yes I eat intestines, yes I shag sheep (but not my own as that would be incest). Yes I like a pint of heavy and a dram of the uisge bertha. Yes I fancy the 'Sturge' (even if she looks like wee Jimmy Crankie) and yes I believe in independence.
Over to you now, lets hear your worst Chris...
Hi Richard
I’m quite upset that you feel I was being racist in anyway. I was only pointing out the fact your in Scotland and work being quite thin on the ground there. You might have to much time on your hands to sit at your computer or iPhone screen trolling the internet to try and make others feel bad to in return make yourself feel big and better. I’m sorry you are ginger that can’t be helped unfortunately but I can recommend a good hair dye.
Going back to your original question regarding my competency I will definitely give you a detailed answer later on today when I’m not so busy doing unnecessary work and over charging my clients for it. Speak soon x
Okay Richy and Chris enough is enough this has totally side tracked the thread and turned into a baiting match. I have deleted one post so either reply with regard to the OPs question or don't post at all.
Reading the last couple of posts it's starting to put the forum in a bad light.
I have taken a look at the video that was posted there was a big hole behind the existing consumer unit.
Now I have not fitted many Hager consumer units but it looks like there is knockouts on the back that knock out as a whole, not in parts so there is more aperture that is needed the only thing that can be done is make good the wall or seal the hole. How much is a tube of intermittent mastic?
I have to apologise for that... Asking someone to bring cheesecake on a date is a bit OTT.... Soz...
INTUMESCENT.
Nothing wrong with cheesecake.
Only if you get it all of the time, and not every so often. or intermittently. Soz Ant in one of those moods, forgive please.
Status
Reply to Sealing a consumer unit entry points?? in the UK Electrical Forum area at ElectriciansForums.net
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hi all! I'm not a spark but know enough to be able to install off grid solar etc. I've just purchased a new house and have noticed the consumer...
5K
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Hi, NAPIT report was carried out due to flood, all kitchen appliances, wall/light switches, fire/heaters etc need replacing. The electrician...
