  • Winner
Reactions: Baddegg and rsgaz
@DPG dont leave me hanging :D
If he won't date you I will.. :hearteyes:
Bring cheesecake..
Awesome. Next time I'm south of the border we should hook up. We could call @Reevio and have a 3 some :eek:
  • Funny
Reactions: Baddegg and Reevio
Ahhh your in Englandshire explains a lot.
Touche!
Can't answer some simple questions, has various videos showing non compliant work and doesn't like it when it's pointed out. Undertaking unnecessary work (and no doubt billing the customer). Childish comments vis vis 'bunch of old women' and now a dumb attempt at a veiled racist joke...
I think I have your measure :p
And to save you the bother - yes i wear a skirt, no I don't wear pants, yes I have a beard, yes I'm ginger (collar and cuffs), yes I eat intestines, yes I shag sheep (but not my own as that would be incest). Yes I like a pint of heavy and a dram of the uisge bertha. Yes I fancy the 'Sturge' (even if she looks like wee Jimmy Crankie) and yes I believe in independence.
Over to you now, lets hear your worst Chris...
Hi Richard
I’m quite upset that you feel I was being racist in anyway. I was only pointing out the fact your in Scotland and work being quite thin on the ground there. You might have to much time on your hands to sit at your computer or iPhone screen trolling the internet to try and make others feel bad to in return make yourself feel big and better. I’m sorry you are ginger that can’t be helped unfortunately but I can recommend a good hair dye.
Going back to your original question regarding my competency I will definitely give you a detailed answer later on today when I’m not so busy doing unnecessary work and over charging my clients for it. Speak soon x
  • Disagree
Reactions: richy3333
Okay Richy and Chris enough is enough this has totally side tracked the thread and turned into a baiting match. I have deleted one post so either reply with regard to the OPs question or don't post at all.
Reactions: Reevio and leebut
Its not there anymore, but I would of clicked the agree button for #104.
Reading the last couple of posts it's starting to put the forum in a bad light.
I have taken a look at the video that was posted there was a big hole behind the existing consumer unit.
Now I have not fitted many Hager consumer units but it looks like there is knockouts on the back that knock out as a whole, not in parts so there is more aperture that is needed the only thing that can be done is make good the wall or seal the hole. How much is a tube of intermittent mastic?
I have to apologise for that... Asking someone to bring cheesecake on a date is a bit OTT.... Soz...
INTUMESCENT.
Nothing wrong with cheesecake.
Only if you get it all of the time, and not every so often. or intermittently. Soz Ant in one of those moods, forgive please.
Bury
Sealing a consumer unit entry points??
leebut,
Simon47,
