W
waitees
Hello
I have had many different answers from local electricians regarding the domestic installer scheme. I have been registered with niceic for nearly a year and have been recently asked to rewire a shop with the top floor turning into 3 flats up stairs. It is currently 3 phase being changed to single phase with new separate supplies for each flat. My question is I know it will be ok to certificate the flats upstairs but where do I stand in terms of the shop as this technically comes under commercial and I hardly see worth registering as electrical contractor as most of our work is domestic and it costs a lot !
Can you guys point me in the right direction ??
if you feel competent doing the work in the shop premises, then go for it. the same regs. apply. just some times the equipment is different.
The point of domestic installer is that you are registered and therefore able to notify and certify your own domestic work. I don't think, but am prepared to be corrected, that commercial work needs to be notified (unless planning permission was required, in which case a copy of your EIC should be given to the building control officer in charge of the job). It will need to be certified however and you should not use your domestic installer certificates for the shop (commercial) install. You can get normal Green (blank) certs from the NIC and use these with no problem for the shop part. If you're competent then you're competent.
Good luck.
If your registered wih NIC for DIS you can change to Approved Contactor ( when your renewals due ) for the same fee ( plus the obligatory inspection)
although your DIS there is nothing to stop you doing commercial
Yep still here, such a good website from honest people !
I have done shops before but set up on my own a year ago and still trying to get my head around the legal stuff.
So am I right saying that the shop install and the results etc can be all put onto a domestic install certificate .
I would go electrical contractor but I just feel at this moment I can't warrant the extra cost for something I am hardly going to use as most of our work is domestic.
As far as certificates go, just buy a standard book of EICs from your local wholesaler.
Or better still, reproduce the standard ones from 7671 using MS Word. looks much more prof if they're nicely printed.
you can sign commercial off yourself. as said. just buy EICs, eg kewtech from wholesaler .
Surely you would still need to have someone like niceic to sign it off ?
Nope, not at all unless someone is insistent that an NIC Approved Contractor does the job in the first place which isn't uncommon in schools. According to the regs you only have to be 'competent' as everyone else has said. The only thing you may need to check is that you are insured under your Public Liability Insurance to do commercial work.
But what I cannot get my head around is that you can sign off commercial with a eic book from any wholesaler but you need to use dis to cert domestic property surely I thought the rules would be the same for both, test, cert and then send off to nic, so all I need is the eic they keep one copy and I keep one and I file it.
Eerr? not being in the NIC myself, I feel I must ask; isn't one of the requirements of the NIC DI scheme that you must have a copy of Part P and presumably have read and understood it??
Have a look at the scope.
And, do NIC really require you to send all your certs to them?
There you go waitees. Use an unregistered EIC (Kewtech, Ethos printed as PC Electrics said) for the shop install and your NIC domestic installer EIC for the flats.
Actually I've just looked at part P and think that as the shop is below the flats then all the work will be notifiable under part P so you should be able to use your NIC domestic installer certs for all the work.
I think your might be right there sjm as this has cropped up before, may have wrote that slightly wrong with nic , no pc you don't send the cert off but notify them via the brcs website of the type of work you have carried out
this is just an example of the bullsh1t confusion caused by part pee. for notifiable domestic work, you need scheme membership or pay LABC megabucks. for industrial/commercial , part p does not apply except in the case of mixed commercial/domestic in same building. as you are NIC< then just get on with it. fill out the EIC/S. copy for client, one for yourself. job's a good 'un.
Maybe not, it's only if the flats are being fed from the same supply that the shop is fed from. If there is separate cut outs and meters supplied by the DNO in the flats then the shop work would not require notification to LABC and DIS EICs would not be used on this part of the installation.
The criteria for whether this work is notifiable or not, is not the relative position of the shop / flats. It is to do with whether any of the flats share a meter with the shop. The OP states that the flats are all getting new individual supplies, therefore the work in the shop is commercial and not notifiable.
Again, AD-P contains the necessary guidance for working this out.
Hi mate
the shop only falls into part p if they share same supply, meters as above the shop doesnt need notifying unlike the flats
as tel states use standard eic for the shop and domestic eic for the flats
As your NICEIC DI registered use your purple forms for the flats, these are the ones that have reference numbers on for when you notify your work.
Then use the green ones from the NICEIC which are availalbe for anyone to use, but for a NICEIC memeber they are designed for work that is not within your scope ie for a DI, commercial work, these are non referenced forms .
The only thing to look out for is your insurance. Make sure you PL covers you for the commercial work.
Just to sum up, there is no requirement to belong to a trade body to carry out and certificate commercial work, unless the client makes such a requirement (check the specification).
There is no requirement to belong to a trade body to carry out domestic installation work if you are prepared to pay LABC in the notification process.
Neither of the above scenario's alter your certification obligations other than the colours of your certificates.
If you are a domestic installer and carry out the commercial installation within the shop outside the scope of your domestic installer conditions then will the niciec provide insurance backing if you are not an approved contractor.?
Absolutely not.
Shop installs - niceic domestic installer
Domestic Electrician Forum
waitees,
IQ Electrical,
