Discuss Single Phase 2 Speed Pool Pump Motor Question in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone
I came across a single phase 230v 2 speed pool pump motor the other ay and became obsessed with how they work and are internally connected , but cant seem to find a diagram/pic of the anywhere. I decided to do my own from what i found on line
My question is have i interpreted the connection of the windings correctly
are they in series or parallel
Thanks in anticipation
Hello and welcome. It's an interesting question. I am not familiar specifically with pool pump motors, but dual-speed induction motors are generally pole-changing motors using one of two configurations; separate winding or consequent-pole.
In a pole-changing motor with separate windings, the stator slots are wound with two completely independent sets of windings, only one of which is energised at a time. These are wound with different numbers of pole-pairs which can be in any ratio. I see for example, a pump motor with speeds of 1725 & 1170 rpm, corresponding to 4-pole and 6-pole. I am not sure what dodges the manufacturers might use to simplify the connection of the start winding and centrifugal switch.
The consequent-pole configuration produces a 2:1 speed ratio e.g. 3450 & 1725 rpm, corresponding to 2-pole and 4-pole. In a consequent-pole motor all the windings are used for both speeds, but they are split into two groups of alternate poles. To change speed, one group is reversed relative to the other, creating adjacent pairs of like poles for high speed (NNSS = 2-pole) or adjacent pairs of unlike poles for low speed (NSNS = 4-pole).
Because pool pump motors generally only require either the high or low speed hot connection at any one time, I infer they have separate windings, as a consequent-pole machine needs both ends of both windings connected.
One type of dual-speed induction motor that is quite well documented on the WWW is the Dahlander 3-phase consequent-pole motor, which switches a multi-group winding between star and delta at the same time as reversing one group relative to the other.
I need to do more research on the single-phase kind though.
So are the internal start, and 2 run windings wire in parallel lie this sketch? Thanks
In your sketch the high and low speed windings are not in parallel, only one is energised at a time, but the start winding is in parallel with the high speed. I don't know how the start winding is actually configured in these motors.
I believe that start winding is wired in series with the centrifugal switch and capacitor. So that when the motor gets up to speed the switch opens and drops the starting circuit. This is when the run widing takes over with the the low speed winding and wired in parallel it would be running at say 1725 rpm now if you needed it at full speed 3450 rpm also independently wired in parallel it could be switched to hi speed winding via a set of time clockd
In a single-speed capacitor-start motor, the start winding, capacitor and switch are connected in series, and that string is in parallel with the run winding. That much is standard. But for a two-speed motor, a single start winding could only have the right number of poles for one of the speeds.
You could have two separate start windings for the low and high speeds with the correct number of poles on each, but that is rather wasteful of cost and size. It would also need separate centrifugal switches and capacitors for both start windings to avoid back-feeding the unselected run winding via the two start windings.
A more practical arrangement would be to use the centrifugal switch to force the motor always to start in high-speed mode. The motor has start and run windings for high speed, plus a run winding for low speed. The centrifugal switch has two sets of contacts: an N/C contact that controls the start winding in the usual way, plus a changeover contact that diverts the low-speed input to the high-speed winding until the motor reaches low speed.
If the high-speed input is energised, the motor starts and runs using the high-speed start and run windings. If the low-speed input is energised, the motor starts using the high-speed start and run windings, then as it reaches low speed the high-speed start and run are disconnected and the low-speed run engages instead.
A search of patents might reveal whether makers have implemented this system on pool pumps. TBH I've never seen a motor wired like this and just worked it out myself, but it's so logical and straightforward that I would be very surprised if something extremely similar was not used for this application. If I get time tomorrow I will search the patents.
I had a quick look and found patent US4623829A from 1986. Applicant was A.O. Smith who happen to make 2-speed pool pumps. It's very similar to my description, but instead of a 2-pole centrifugal switch it uses a dual-make N/C for the start winding and to link the low-speed input to the high-speed winding. A triac, triggered by the voltage across the start contacts of the centrifugal switch, serves in place of my N/O contact to connect the low-speed winding to the low-speed input once the switch operates. It also shows transformer-connected start windings.
The patent references others which I expect will show a purely switch-based solution without the triac, but I don't have time to look at those now.
I think i have something similar
is there a schematic of it
Meantime heres some more i came up with
On initial start up the T104 timer clicks in and energizes the start winding and low speed winding. Once the motor gets up to speed the centrifugal switch opens and drops the start winding circuit so now its running only on the low speed run winding. So it always starts and runs initially in low speed. Now if you need to step up the speed the T106 timer drops the low speed winding and energizes the hi speed winding
Reply to Single Phase 2 Speed Pool Pump Motor Question in the UK Electrical Forum area at ElectriciansForums.net
Hello. How i should connect this 1 phase 2 pole 400v cooling pump? If i apply 1phase 230v and neutral it Will only growl and "spin" very very...
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi, I am trying to wire a two speed switch to a three phase motor. I have continuity checked the switch in both positions 1 - Low and 2 -High (See...
