skts x 2 earth terminals | on ElectriciansForums
Discuss skts x 2 earth terminals in the UK Electrical Forum area at ElectriciansForums.net
England
Been 2nd fixing today, which i've not done for many years. I've noticed that both Volex 13A twin & single sockets have 2 x earth terminals. Is that now standard? I thought that requirement was only applied to sockets that served a lot of IT equipment. Even years ago i would sleeve the earths separately, but then into one terminal. Is there any electrical reason for the change? Thanks
Just so the socket can be used for any situation.
Just get into the habit of using both terminals when doing a ring main, it only takes a few seconds more.
Ohh i've no problem with it at all. I've used them both today. Even bent each wire earth wire back 3 times to ensure good connection/strength. Just wondered why they are being introduced
If you used both terminals for the ring main the earth within the socket would be completing the cpc continuity. I always put both cpcs in one terminal and the other terminal for the back box bonding.
Right, understand. so no requirement as such then to use both separately on a ring. I suppose if both used could make fault finding bit easier as you could disconnect 1 x earth as opposed to untwisting/ separating the 2 cpc's
I never twist, i always sleeve them separately then put both in the same terminal. Tighten until it squeaks with pleasure then tug test :)
I didn't say you should, its just a habit to get into that hardly takes any extra time.
But why get into the habit at all? I am not trying to be smart or funny with thee if it is coming across that way. I just don't understand the reasoning. Which is true for alot of the stuff i read on here and 99 times out of 100 i come away having learnt something so i thought that may be the case here!
So when you do a IT related circuit (assuming you do commercial) you are already in the habit - one of my colleagues has been heard muttering to himself when on commercial installs because he has 'got into the rhythm' and then forgot to use both terminals.
Reply to skts x 2 earth terminals in the UK Electrical Forum area at ElectriciansForums.net
What is the distance from the point outside the house to the shed?
Thanks Brian. I'll keep doing it then, no harm I suppose. I am lucky in that being DIY, I have the luxury of time when it comes to this kind of...
Recommended Sponsor News
Hi everyone,
