daspark
Hi all!!!
I have found a multimeter for a good price on the internet. It is the Kewtech KT117 Mulimeter. Does anyone have good or bad reviews on it? I am asking as the price is so good. Thanks
Hi all!!!
What do you intend useing this meter for? Its designed for electronics use rather than low voltage AC ( mains ).
If you are looking for a multiple purpose instrument for testing fixed wireing this is NOT the instument to use.
Great for fault finding on elecrtonic equipment though.
If you're using separate units for installation testing, this meter is fine for continuity low ohms measuring, looks quite robust too.
as above, what do you need your meter to do and how accurate? are you going to be measuring 0-10VDC or 4-20mA instrumentation readings where accuracy is everything? or just checking for voltage present??
Thanks for the input. I'll be mainly measuring Extra Low Voltage systems. Although with some Low Voltage work. Probably should have stated that. I think it could be a shout.
Specific Multimeter
Electrical Tools and Products
daspark,
daspark,
