Discuss Starters and motors in the Electricians' Talk area at ElectriciansForums.net
View attachment 27775What's this?
was looking at a motor the other day and when I measured across all I got was 230v to Earth but not 400v between.
View attachment 27774Rating ate.
I know nothing about controls and motors. I measured 400v at isolator , which then goes to id say is a starter of some sort (pic). I then measured 230v at motor housing. I used martingale gs38 testerWhat controls the motor? .... DOL, VSD, Star/Delta, Soft Start etc etc?
Has it got speed control?
What meter are you using to get your voltage?
What's the nature of this post... is something wrong with the motor or its operation?
Agree totallyNeither do I, that's why I leave it to others!
I measured 230v at all points on motor to earth but nothing between connectionsIf it's supplied by a variable frequency drive there's a good chance your tester won't be able to make sense of the supply at the motor due to the high carrier/switching frequencies.
Guys and divas , I only check power at devices after that the boss sends it back for specialist which I asumme in this case is an electrical engineer .
View attachment 27778 Dave not my job now so fuk it . Just a little interested .
Reply to Starters and motors in the Electricians' Talk area at ElectriciansForums.net
