My mum bought some storage heaters with in built thermostat and I noticed there were 4 wires, live, neutral, earth and a black cable. I've wired storage heaters before and they didn't have this 4th black cable. How is this 4th cable wired? She has Economy 10 in the house is it possible to wire it direct from fused spur from an Economy 10 socket?
Thanks in advance.
Would they be Dimplex?
I've just installed a QRad by Dimplex, the black lead is something to do with their control system. I think it's referred to as the Pilot signal. If you're not using their controls, put it in a terminal as under certain conditions it can rise to 240v.
This is what I can remember from a brief read of the installation manual.
She has two Dimplex storage heaters but these have the standard 3 coloured cables, which I connected up easily easily enough. However the other isn't a Dimplex storage heater it has the temperature dial at the top of the heater to adjust the temperature, so I don't quite understand what the black cable is for.
apparently,according to my wholesaler anyway traditional storage heaters are not going to be sold by manufacturers of them after January (euro directive) and new ones will need a permanent supply as well to power programmer and instant heat/fan,dont know how true this is,but they are selling old ones off
those bl**dy euro crouts stick they nose where it not needed.
I don't understand why it would be for a programmer? It's a night storage heater, the supply to it is already time controlled, what's the point of additional time controls?
United kingdom
Storage Heater with 4 wires
Sparky_marky2,
Br40hh,
