Discuss Strange problem with PIR/motion sensor switch in the Lighting Forum area at ElectriciansForums.net
Hi, I have an odd problem with a motion sensor switch in a bathroom.
The sensor detects motion and switches the light on, but then doesn't switch the light off.
However, when I switch the fuse off and then on again at the fusebox, it resets the motion sensor, which works fine, but only once - after which, it goes back to turning the light on but not off.
I've tried replacing the motion sensor (it's a Timeguard PIR, with five terminals, including a switched live).
Any ideas please? I can't work out why this would happen?
Thanks!
have you looked in the light and checked that there is only a switched live running into it?
also are you sure you are buying the right type of motion sensor?
have you tried waiting for the light to turn off say 10 minutes after you leave the room?
Can you show us how you have wired it up?
Thanks for all your responses!
The timer is set to the minimum, 30 seconds. The light stays on permanently (or at least, more than an hour). I've included a photo of the wiring set up, maybe that will help! IMG_20190419_173011.jpg
Reply to Strange problem with PIR/motion sensor switch in the Lighting Forum area at ElectriciansForums.net
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
On either side of my front door is a motion sensor wall light - it looks like both lights operate from one light switch inside the house. The...
My 4 year old son won't go to bed without the light being left on and insists his door is closed when I leave. When the door is opened later to...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
